Time has come to move this car due to "other" commitments and a new project or 2
Car is located on Central Coast NSW and has been in storage for just over 12 months
Postage is fine given you organize it
All prices are somewhat negotiable
R32 shell $5000
Guards are in primer and rest of the car is white. Some rust around the rear window as usual. Car is around 170mm wider than factory
Body:
- CUSTOM CUSTOM CUSTOM
- Spared no expenses on guards
- Custom moulded to car
- Custom inner arches in rear
- Veilside Front Guards
- Veilside Rear Guards
- veilside Side Skirts
- Sunroof
Suspension/Driveline:
- R33 LCA's
- Adjustable rear camber arms
- metal pinapples
- mini spool
- Strut Braces front and rear
- Hicas Removed completely (all lines)
- R33 power steering pump
- Hicas Lock bar in rear
- Slotted rotors
- r33 clutch master
RB25 series 2 motor (88,000Kms) $3500 (open to offers)
- No hotside
- Plazmaman Plenum
- Plazmaman throttle body
- Splitfire coilpacks
- Big Injectors
- BMI fuel Rail
ARC intake box $300 (never fitted and imported directly from japan)
Hybrid steampipe many (brand new) $300 (T4 split pulse)
Aero mirrors (assuming gktech) $50 (blue lens)
Tilton twin plate (95% on the plates) $1000
R32 Gtst box $700 (with exedy 5puk)
ISC N1 coilovers $650
Bolt in half cage $600
Front Mount 76mm used $60
Front Mount 100mm (brand new) $150
52mm Radiator $70
Oil Cooler and relocation Kit $200 (with all lines etc)
Tial 44mm External Gate MVR (water cooled) $350 (barely used)
3.5inch kakimoto exhaust $350 (came in at 88db) so legal J
Greddy Swirl Pot $100
Fuel Pressure Regulator with Gauge $60
Big Fuel Pump (unknown brand) $150 (intank)
Adaptronic computer $650
Bride door trims $300 pair (slight blemishs)
Bride Gias II Seats x 2 (brand new) $700
Custom Seat Rails (brand new) $200 pair
Carbon fibre A pillar pod 60mm gauges (brand new) $100 (slight ding as seen in pics. Cant see it when gauge is in)
Pics will be up shortly when time is available.
Edited by Frosty
  • Like 1
How much for the injectors? what are they and also how much for the fuel rail? will you separate them? if need be I can give you stockies to throw on
Edit: Didn't read the whole add. xD
Edited by -Jimmy-
at this stage not really keen to separate them from the motor as i would want to sell it as a whole. That being said if there is no interest in the next few days ill let you know
need to move this extremely quick
clutch in or out of the car? also can i get a pair of those black shorts ?
twin plate is out of the car. forgot about pics of it....
you can have her for 8k (get a free r32 aswell) lol
Rb 25 t4 twin scroll mani how I may have missed but didnt see a price listed? 44mm gate? What brand?
Josh
Would you take $700 for the seats, rails and door trims?
If so I'm keen and driving to Sydney on Sunday the 6th anyway to pick up a motor
Josh
price is listed as $300
Tial genuine MVR 44mm
Manni can take 44 or 50mm
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
