Hey Guys,
I have a few items for sale from a change in direction on my project car. My location is in dubbo, nsw. Most parts will be pickup only but im happy to drop any/all this gear off at a courier depot.
I was building up an R32 GTST and got most of the way through before i decided to buy an R32 GTR so i have a duiplicate of a few bits and pieces. Prices are fairly negotiable but any low ballers will be laughed at or told where they can put their offer.
1.
First up we have an RB26 engine out of the GTR i have at the moment, i dont need it because i have a forged RB26 in the GTST at the moment that im going to put in it. the engine only has 117***ks on the odo, the engine is still in the car and running, will do a compression test and post it when i have a chance.
looking for between 3000 and 3500 depending on what bits you want with the engine.
2.
I have a BRAND NEW, NEVER USED fully manualised R33 auto box that was built by the guru's at MV Automatics, this box has had one of their stage 2 kits put in it and will support up to 350kw. With it will also come a gearbox controller, A single piece drive shaft, 3500rpm stall converter, modified gearbox cross-member. Pretty much everything you will need to bolt into your R32 GTST and can be made to fit an R33 easily enough!. Have recepts for gearbox and converter.
what everything cost me:
Box: $2800
Converter: $500
Controller: $300
Driveshaft: $300
Crossmember: $100
= $4000
what im asking: $3000
3.
The 5spd manual gearbox out of my new R32 GTR is up for grabs as well. standard box, runs fairly well but crunches a bit on 4th when acelerating hard or coming back from 5th.
asking $500
4.
Brand new, installed but never used BC racing coilvers with external reservoir to suit R32 GTST. Cost me $1600
Asking: $1300
5.
Brand new, never used tho has been sitting around for a while: Alloy autobahn radiator to suit GTST/GTR (unsure if it will fit in any other skylines, i assume it will)
cost me $350
asking $250
6.
Used Evo brembos (front only) and a kit (brand new) i bought to install them on my skyline. comes with calipers, conversion kit, brembo rotors to suit kit.
cost me: Calipers: $700
Conversion kit: $500
asking: $900
7.
Brand new, never used Ebay 35/82 journel bearing turbo.
cost me $600
asking $400
can post this item at buyers expense
8.
Brand new Ebay spec topmount turbo manifold to suit above turbo
cost me: $300
asking $150
will do a deal if someone wants the manifold and turbo.
9.
Used Single stage Turbosmart boost controller
$50
Pics of everything coming soon!!! Please PM me if you have any questions
More stuff to come soon when i go through my garage and work out what i actually have in it...
- Matt
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
