I have for sale a Supertech RB25 Solid Lifter Conversion Kit
It contains:
24 Supertech Valves - +1mm
24 Supertech Solid Lifters
24 Double Valve Springs - 83lbs @ 35mm Max lift 14.30mm
24 Spring Seats
24 Titanium Retainers
The kit is brand new and never used. All the valves are still in their packets except 1 that I took out for inspection. All the other parts are still enclosed how they came from the supplier in airtight lock bags
$1800 for the kit
  • 4 weeks later...
I did my homework on the supertech valve train some months ago, off memory they only make one type of dual valve spring, which has a rate and height for their 1mm oversize valves and theyre solid lifters etc. however they have different composite valve's etc. can you elaborate a little more on exactly what they are?
Reason is so that i know what i am getting for my money and, so i can redo my homework on the price :yes: then throw you a reasonable offer.
  • 3 weeks later...
Hi BJ,
The part number on the packets of the valves are NIVI-1052-SL and NIVN-1052-SL. Supertech list these as Black nitrided for intake and Inconel for exhaust.
Link here for information: http://www.supertechperformance.com/catalog?mk=8&ca=328&en=76
It's the only valve they do for this application that I'm aware of. Retail on this kit is $2200-2400
  • 1 month later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
