I have a '89 R32 GTS4, in need of a set of front wheel bearings. All the bearings I can find only cover 6/91 onwards.
Anyone able to confirm that the wheel bearings throughtout the R32 AWD range are the same part number, ie is the GT-R same as the the GTS4, and '89 on is the same as 91 on.
TIA.
https://www.sau.com.au/forums/topic/432365-front-wheel-bearings/
Go to CBC
I got new wheel bearings, seals and snap rings for around the $400 mark.
Also made a bearing/ seal press tool to get them in square and without damaging them.
If you want to cover the postage cost to SA, I'll do it alot cheaper than a mechanic for a fellow 1989 r32 GTS-4 owner :)
