Just wondering if a Neo turbo is a direct replacement for a regular RB25DET in a 1996 stagea? I read the Neo turbo is not as hardy as the older series of turbo, but the Neo seems to be more available and priced low (I imagine its because they arent wanted) But if they fit, are they acceptable if you stay below 9 psi?
  • Like 1
I wouldn't suggest that they are priced low. I would have said exactly the opposite, that because they have the OP6 exhaust housing they are actually in demand compared to R33 turbos. Having said that, even at $400 they're not what you would call expensive.
The only reason that you would consider them to be more fragile than the R33 turbo is that they have a plastic compressor wheel (which the later R33s had anyway). That is a little more prone to death than the alloy one.
The main cause of death is still the ceramic turbine falling apart if you spin them fast.
Yes, it is an upgrade, yes, keep it below 9 psi and you'll be fine (you could even run more - I'm running about 12 on mine - I'm sure it will either keep going for years and years or just crap itself totally this afternoon).
Thanks, so is it a direct swap, or are modifications required for fitment? Also assuming no change in the amount of boost I want to run, how will the stock ECU cope?
I have a neo turbo on my R33 on standard boost. It is a straight swap with no modifications. Standard ECU handles it fine
I have a HKS GT2535 for sale atm. Its a direct bolt on. Ball bearing cartridge in perfect condition with no bent or chipped fins. Has roughly 15,000kms on it over 6ish yrs. .64ar standard 6 bolt nissan dump pipe flange ns111 28 exhaust wheel with a 56 trim 69mm comp wheel from memory. 'Google it for definet specs'.
Good for 250kw atw's on 98 and 270ish kw atw's on e85. I Made 235kw atw' on 1 bar/14psi of boost 98 fuel many many yrs ago. Lol. Comes with all lines and will throw HKS dump in to for the right price. $900ono. Will by far out perform the op6 neo stocka and normal 25 turbo with ease with similar response. Pm if interested and will not disappoint for farrrk al more outlay to a stocka.
cheers josh
Could be a possibility, what rpm does it create useable boost from vs the stock turbos? How will it function with a standard ECU? Keep in mind Im not chasing power, the car is mainly a workhorse vehicle and so the stock response and low spool rpm is crucial.
cheers josh
It spools no different to a stocka and will be fine on s stock ecu set up on 9-10psi. Itll have a stronger midrange aswell. With room for improvement down the track if you wish. :)
  • 1 year later...
Sorry to revive this but just interested to hear if there was any added lag or improvement switching to the NEO (OP6) turbine over the R33 turbo
Thanks ..
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
