The Nistune won't be what holds you back, but you should be looking at stronger head studs and beefing up the auto if you plan to push it. No reason the stock engine won't produce 400kw plus if you can get some ethanol into it. Reliably? That's anyone's guess.
Computer will do what you tell it ! I'm running stock neo with mls head gasket and studs and have been making 338kw on 16psi for a while now using e85, been meaning to turn boost up and retune for a while :)
Ok I have just fully forged the engine, ARP headstuds, steel head gasket. All the head refreshed seals ect. New crank, new pulleys, damper. New pumps (oil,water) belts. M V autos stage 2 valve body, billet servo piston, and band.
E boost 2, stage 2 steel hybrid OP6 tubbie. Nistune.
Will be fitting a 6 boost twin scroll manifold and a GTX35.
What I'm asking is where is the nistune limit ?
Can it handle this safe ?
Or do I need to look at get a standalone ecu to look after things ?
Nistune does not have a "limit" as such. It can be used to tune to what ever your engine can make (200kw or 1200kw) but if you are flush a more expensive ecu such as Link or Motec will give you a few more features. Since you already have the Nistune just go with that until you have found a reason to replace it. I would get a GTR box first with the power you are looking to make. I presume you have already upgraded afm, fuel system, brakes and suspension.
I'm not too good with this stuff, so correct me if I'm wrong.
A nistune will hold as much power as you want and what your afm and other parts etc can handle, so all it can do is tune your mods.
Some stand alone computers have other features, like: launch controle, map sensors, digital displays(nistune can do this with ecu talk), inbuilt boost controllers etc.
I have not seen the maps and parameters of the air ign fuel on a nistune so I can't comment on which one will give you a more precise tune.
I'd firstly work out how much power you want and what mods you have done and then work out if your sensors and equipment can handle it. But that's why you're in here, someone to help you and who has had a similar setup.
Call Dvs Jez and book in a time to go see him in nsw on the central coast. He has probably dealt with your setup before and can tell you what you need or don't need to achieve your power/circuit/drag times/goals.
Nice list, but what injectors are you going for? Have you installed a decent fuel pump? Have you matched the torque converter to the GTX35? Is the exhaust a free flowing 3.5 inch system? Are you close by an e85 servo? These questions are much more important than the Nistune one you asked.
I fabricated some parts for a GTX35 setup on an RB25 the other day, it made 430kw at fairly reasonable boost on the factory manifold, with plenty in reserve. I just hope you have the rest of the supporting mods, it's probably good for 500kw on a perfect setup. Here is the graph for comparison, yours will be a little laggier I would assume.
  • Like 1
Other mods -- Z32 Afm , sards 550cc injectors , CP pistons,BC rods,ACL bearing all round,255 fuel pump , 3" turbo back free flow , AEM AFR , R33GTR front/rear brakes, Tein coilovers,3.5" large front mount IC, Apexi air filter, apexi twin piston dump valve. 14 row oil cooler remote filter, R34GTR wheels, R34GTR bumper and lights from the car that set the R34GTR lap record of the Nurburgring. Masa body kit with R34GTR rear fenders all painted KH3. Not that most of the mods are relevant to my tread question.
Reason I ask was a tuner told me he would like to push past 400kw on a nistune. He said that after 400kw he would push the nistune due to the basic limits it supports stock.
I want a pic of this car!!! So it's got a 34 gtr front conversion ? And rear gaurds???? Your tuner is incorrect your nisstune is capable well past that but your fuel system and injectors will not get you any where close! If mike says its rated for 400 he would know ! But I know they used to be rated to 315 . Also over 350 if your looking for big numbers it starts to pay to go for a ffp , and even with an auto at 400 be prepared to start snapping the puny axles . Don't forget that your trans will soak up approx 12-15% drive train loss as well
Yep along with the GTR box I have GTR diffs and axles which are bigger than the stock Stagea items. Have you put up a pic lately? Would be nice to see the R34 conversion
I run a surge and a 044 and 1000cc injectors I would prob even upgrade that over 400. Your 550 won't get you anywhere on e85 and about 240-270 ish at a guess on pump 300 if you use water/meth injection as well
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
