I am making 312 awkw with my Deatschwerks 550 injectors on 98 petrol - I would say the limit on petrol is about 400kw.
Will a 455lp do the trick ?
What's the limit of the 550cc ?
I will stick up some pictures ASAP
so they will really take 300-350..lol, he overates his stuff, big time, and then theres the stagea weight...
cheers
darren
You must know different ?
It's got the option to work, if not I'll be fitting the getrag box sooner than I thought maybe.
I had a built r33 auto in my last car, cost for a 700hp rated auto, for rwd only, in a lighter car was $3500, all KEAS internals, ported oil galleries, etc etc, then another $1500 for an 8" custom TCE 3000rpm pro street stall converter with transbrake setup. if your in vic , go and talk to Bayswater automatics, well priced and supply/fit and build with quality KEAS parts.
As for a rebuilt auto to handle 4wd.... that's a whole new ball game. if it were me aiming for those power figures, id convert to RWD and put in a transbraked C4 auto, with minimum 1500 stall converter.
To keep it auto you would be mad not to stuff an RE4ro3a in there as they can be built to handle 1200hp.
My box is an RE5ro5a and is just taking the 350awkw I am pushing through it (after many dollars have been thrown at it), although it would be putting out 400rwkw in manual rwd form.
well i can think of 4-5 ive had or got for mates and they've all blown, and then theres all the other people i know that
have blown, mike woudn't get any feedback...as they all convert to manual after that.....
they didn't last long..i got 2 days out of one...
the trans he rates at 300ish rwkw are just valve bodys..they generally blow at 240-250rwkw
(and thats in a skyline..not a heavy stagea, the only saving grace in a stagea is it doesn't wheelspin so your not on or off the throttle wheelspinning ... which electronic based boxes really don't like....)
or thats about there limit ..you can't expect them to hold 300...
his boxes are fine, his power ratings are up shit creek
2 options: sane street car Re4Ro3A built by kEAS with adapter(pretty sure pauls back in business now. and he quoted the
cheapest price for them ..)
or insane ...powerglide or turbo 400
thats your options...no B or 1A trans will hold...it will just be a complete waste of time/money and end in tears
pretty damn quick...
if my stagea was a project car, not a family car..id go 3.0 bottom end /neo head/10.1 comp ,E85..Pt6466 and a Re4Ro3A...lol
cheers
darren
Edited by jet_r31
Interesting ... I've got the RE4R01B Tiptronic box in the GTT, still stock but trying to work out what to do with it.
You reckon it's no good to handle ~300ish rwkw even with a rebuild and a KEAS kit? Also, is Paul in Melb by any chance? Interested in having a chat.
Cheers, and sorry for the hijack..
around 300 you will probally get away with a big trans cooler, MV valve body and billet servo..thats what i have and its
held 290ish rwkw atm. i am not saying they are crap..just overated
But i woudn't try it with a GTX3540 on E85 on kill, lol , that would end in tears..
cheers
darren
  • Like 1
The GTX35 twin scroll is going to get its fully chance to produce its self, with the manual get-rag once it's fitted. Nistune I'm happy with the replys from all on the limits.
The triptronic valve body ect I just wanted to see the limits. And I will find the limits before the conversion to manual.
1st start today with the new forged engine and box. Running in is not much fun with no boost.
Pictures to follow soon as poss.
Thinking of fitting R34GTR rear lights, just going to have to have a play and see if I can work them in to look right.
Running in should be completed on the dyno with the initial tune and after an oil change you should be good to boost and drive normally (just watching for leaks and monitoring temps and oil pressure). Then another tune when you have about 10K on it.
Annually or 20,000+ km should be fine but I end up changing it abut every 6 months (10 - 15,000km). I get Nismo filters for $30.
Good oil, what is the turn around before you change the oil and filter ?
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
