Oil change every 5000ks on a performance engine, filter every 10,000
And definitely change regularly if running e85
Jesus kiwi I change my work vans oil more regularly than that lol
Annually or 20,000+ km should be fine but I end up changing it abut every 6 months (10 - 15,000km). I get Nismo filters for $30.
maybe if you own a KIA or something..5000km km is the norm, or if you race..before and then after is good, and with 40+psi a top up in between..lol
i woudn't like to be your engine bearings...lol
cheers
darren
Ok it's not a ? On oil anymore it's what's going in.
Picked up a special conponants standalone ecu along with a OS Triple plate to match my Getrag. Just on the look out for a R34 pedal box and I'm complete for the convert. Oh and the manual centre gear surround for a S2.
Capping power @ 325 until convert, my tuner is trying to convince me to fit the GTX42. Wrong car in my eyes for the 42 so I'll stick with the 35.
On test mind a GTX40 spooled up 750rpm faster than GT35. The GTX40 made the same power @ 0.4 bar less and 50ft/lb more than the GT35. For a big turbo they not too laggy.
lol, f**k fitting a 76mm turbo to a manual stagea....weight and lag, be awful..and slow, especially in this day and age with mid frame 62-67mm turbos that
flow so much air..
cheers
darren
The gtx40 was on a R34gtr and the GT35 was also on R34.
I have said I'm sticking with the GTX35 myself and will make best do with what I have.
The weight issue is something I can work on.
900kg front and 700kg rear axles at the moment,and will be reduced in weight in time. Getting as near to 750 is the end target I'm looking for.
Lag is part of the game, just need to reduce best I can.
Cheers Lee
Edited by Stealth400
  • 2 months later...
Car looking good. Needs an RB30!
I have a GT3540R with a .63AR exhaust for quick pickup (weighs in at 1800kg with driver). Haven't been able to get to the drags yet -hopefully these holidays. Currently at 314AWKW - here is the boost curve:
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
