I have a 2002 V35 350GT sedan and the radio/CD etc and the climate control system are not working. It was happening intermittantly about once a week or so but now does not work at all. It would shut down for a few seconds or sometimes a minute or so. To me it sounds like something loose.
It seems that it is not getting power but when you turn on the lights all the lights on the radio and cc work but none of the buttons work. The display on the middle dash works and shows the time and temperature. 'Auto A/C' is showing permanently and both the temperatures are stuck on 18 degrees. The fan speed display varies most times you start the engine, sometimes it's 1 bar, then 3 bars next time etc. The icon that shows the air distribution varies most times when you start the car. It may show air to the face and feet, next time it may be just the face then next time it could be feet. Lucky it's not winter because if you get 4 bars on the fan and air directed to the feet with the air con on you would freeze.
It's strange that the lights work but the buttons don't. I've checked fuses and looked at the obvious things but haven't pulled the centre console out as yet. I'm hoping someone may have had a similar problem and can give me some tips. Here's hoping.
Hey mate this is a common problem and its actually happening to me at the moment.
It is an expensive fix and would be more worth your while to do what im doing and upgrading to a double-din headunit (Clarion CX501 to be exact)
The auto a/c is a feature of the car that controls the fan speed etc depending on the temperature and the engine temperature so if you want to warm up the fan speed will be very low until the car is warm and the heater will actually work.
Anyway the symptoms are the same at mine.
Chris rogers covers it here as well: http://www.skylinesaustralia.com/forums/topic/240794-v35-faq-read-first-before-posting/
Heres an example of the easiest way for you to install a double din: http://www.ebay.com.au/itm/METRA-99-7604-INFINITI-G35-03-04-SILVER-DASH-KIT-COMBO-/181072427505?pt=US_Car_Audio_Video_Dashboard_Installation_Kits&hash=item2a28c1f9f1
Although the metra kits arent perfect and it would be better if you could source a JDM double din fascia (found on base models, same as M35 stagea)
If you are worried about the 18deg, im pretty sure unplugging your battery will turn the aircon off.
good luck!
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
