Hey guys I am trying to find some info about installing an arc twin entry cooler with an arc airbox.
Not much out there on the web. Has anyone installed a twin entry cooler whilst maintaining the arc air box?
Cheers
adam
  On 28/09/2013 at 10:21 AM, AVGR said:
I have a bad feeling the arc airbox is bigger then stock airbox :(
What did u do about your return bov piping?
Sold the whole kit! I toyed with the idea of fabbing up a new pipe, but it would have been a shit fight and I wasn't going to take a hole saw to my car.
What's the setup of the car?
Built 26
272 hks cams
sard 800s
Dash 5s
d jethro
tomei dumps
arc prestige r rad
arc air box
top mount catch can into front washer catch can combo
hks hard pipe kit
hks afm delete pipes
Hks front pipe
hks super turbo exhaust system
nismo fuel pump
greddy boost controller
orc triple plate clutch
Tein super streets with edfc
ap racing front and rear kits
whiteline front and rear sways
Should have researched bit more before buying the intercooler kit. But I guess I was thinking a specialised kit would fit without too many mods.
Might have bite the bullet if it fits with pods. The weigh up of the intercooler and airbox is an easy enough answer.
Cant see much on the interwebs so I think ill give it a go to make it work
  • 6 months later...
Adam,
I'm interested to see what you come up with. I'm interested in the same IC for my BNR32.
Problem is that the GTR is setup for a single entry charge pipe so I'm curious to see how two entry pipes will work for the GTR.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
