nice one geeza! hehhe pics pics pics... oh and more details, can't just say supercharged V35 and leave it at that... what supercharger, what mods?
oh and welcome aboard, may not be an RB, but you wear the SKYLINE badge as proudly as we do so who cares.
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-882843
thanx for the welcome... nice
car standard except ati procharger (7lb pulley) centrifugal s/c and intercooler. mods to do this year = nismo sway bars and springs/coilovers (drop it an inch or so) will post picture link tomorrow.....
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-882957
  Rezz said:
I'm now officially in the process of getting a V35 Skyline 350GT Coupe... I luv em.
i've done 100k miles in r33 & 34's (stage 1 mods) and although they are completely different, i don't regret moving on... you have to drive these mothers to appreciate em.
yes I'll probabley rot in hell for saying it... i know i know
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-882959
as soon as Nissan Australia finalise its decision on whether it will bring the V35 into the country or not, enabling grey import compliancers to apply for plates.
Actually they could now seeing that Nissan isn't bringing them in, but they will have to bring one in for testing and approval at their cost, and if Nissan Australia decides that its gonna bring em in on volume then the compliancer loses out.
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-883015
  funkymonkey said:
are you trying to make us jealous rezzeh :) make sure its kitted out to the max too... impul everything :rant:
Shall do... but I'm only gonna do Impul filter and steerring wheel, the kit will be "R-Spec Datasystem" y'know the one? Oh and some gunmetal Work Emotion CR Kai's...
https://www.sau.com.au/forums/topic/43250-newbe/#findComment-883026
    • Is it possible to get them dilled and taped if its not there. Same for oil feed and turbo drain, is it easy to get them taped or i should get the supply from somewhere else?
    • I'm not doubting it does something, there's clearly a reason why Nissan bothered with it on the transmission/diff/transfer case but it's more just the effort of finding a drain plug that isn't going to have some unexpected design problem that makes me lazy. For example even the Nismo branded ones here spec way less than the factory 20 N-m. They say only torque to 10 N-m. That is getting absolutely trashed the moment you take it to any mechanic who isn't familiar with the specific requirements and assumes it should be torqued to factory spec.
    • Same same. DE block has no oil squirters though. You either live without them, or go to the effort of adding them. The type of pain is up to you.
    • Thanks for bringing this workshop to my attention, i didnt know about it before and Jessie did some Fabolous work on my car! Helps that its close to home as well, hate having to drive half way across melbourne for a decent workshop.  https://www.instagram.com/p/DIPwaQ1yHMe/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
    • Hi, doing a rb25de+t build right now on my r34 4door that got a 75t block, wanting to use rb25det piston but just want to confirm the 25det and 25de rod, crank are same?
