This is a beautiful car very reliable car, really don’t want to see it go but financial circumstances force me to. This is my pride and joy it is awesome car to drive.
Rb25det NEO engine 5 speed manual with 125xxx
Well looked after, full service done every service
electric/windows/mirios
central locking
Alarm / immobilizer
REG till July 2014
MODS
Interior:
Full centre console carbon fibre
4 AUTO GAGE gauges smoked face,
water temp, oil temp, oil pressure and Boost.
Carbon Fibre Kick Plates / Door Sill Plates
Turbo timer
Audio System:
Single din Pioneer head unit
Herts 6" splits in front
Herts 6.5" two ways at back
Herts 4 channel 1160w amp
Kenwood 12" sub
Kenwood 1000W mono block
Exterior:
White with Gold pearl pant work
Full body kit
Tommy Kaira original front bar but its cracked as someone backed into me at a parking lot :rant: , no damage to the car just the front bar, but is repairable because its a rare and expensive bar,
I have a Bomex front bar that just needs spray and fit with smoked indicators
Xenon HID light
smoked side indicators
Carbon fibre eyelids
Nismo Carbon Fibre Pillar
Ray Volk look alike Mat Black Brand new put on only last week
18x8 Front with 235/40 ZR18 Nexen Tyres Brand new
18x9 Back with 255/35 ZR18 Federal Tyres Brand new
All round HSD coilovers
Also have a fiberglass R34 GTR wing for the right price I can give with the car.
Performance:
R34 GTR brakes with slotted discs
Exedy Heavy Duty Clutch
Aluminium Radiator
FMIC 300x600
2.5" custom cooler piping so no holes have been cut in chassis completely legal
Custom 3" aluminium intake pipe with a 3A racing Pod filter
R33 GTR Turbo back 3" exhaust
Turbo Smart T boost controller boosted to 10psi safe not to blow anything
Tunned at Chequered Tunning 2 weeks ago making 206RWKW
$18,000 neg
Lots of time and money have gone in this car, I love this car but it must go, I am negotiable but don’t try and negotiate with me by TXT if you’re a serious buyer come have a look and we go from there.
Located in Clarinda 3169 Melbourne Call or TXT Luke 0413737028
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
