Hey,
Does anyone on here have a car trailor??
I need to transport my car from the back of a friends house to my house, but cant afford to get it toed seeming its from middleton (swan valley) to kinross.
If anyone can help out, i would really really appreciate it, and in return ... :)
I have 5 weeks off uni starting from next week so im pretty flexable with time.
If you can help out, can u please reply to this thread.... or if u know some one on here with a car trailor, who? so i can contact them and beg!
https://www.sau.com.au/forums/topic/43254-does-anyone-have-a-car-traylor/
Its from the swan vally to joondalup.
Thing is though, ill have to get him to drop it off at the mechanics, then bring the car back to my place. The mechanic is going to look over the car for me and check out what needs fixing and tell me how much. Depending on how much that is, ill need to bring it home if i cant afford the repairs straight away.
So the trailor is a good option, cos then i can bring the car back home too.
but thanks for the advice :)
Is the car driveable but unlicensed?
If it's unlicensed you can just get a permit from a traffic office to drive it.
If it needs towing there is a company called Car Trailer Transport that can pick it up for you.
Cheers
Yeah thanks chris, i looked into that. Cos somthing like $15 to get a permit to do that... but i have no idear if the car would get me there. I dont know the condition my brother left it in. All i know is that it turns on, and thats about it. I sopose that is a good start.
Adam. I wish i had checked this earlier!!!!!!! Its prob a bit to late now to sort it all out. Do you know if ur friend is going to have it again anytime soon? Im not in a hudge rush.
oh its still avalible?? If i can atleast get it to my house, then its not that far to get it to the mechanics. Im going to go see the car today, and see if it runs. If it does move, and i think i will beable to get it to my place, Ill just get a permit to move it. Ill let you know tonight.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
