Drop saws such as Brodo's (cold style) have an advantage in that they remain true to the cut that you are making as the cutting disk is much stiffer, were as if the bandsaw blade losses tension it can wander and no longer make a true cut. The slow cutting of the Brodos can lead to them fouling the cutting teeth if use with aluminium based alloys, not such an issue with the bandsaws. Drop saws designed for aluminium use use a different tooth pattern and a higher cutting speed than those for ferrous materials.
Your options are either cut off drop saw which will do the job but annoying that you have to clean each cut up alot whereas bandsaw does a pretty clean cut and not much if any clean up is needed. I personally have been using drop saw but will be changing to a bandsaw when I get the money.
$100 cut off droppy is all the average guy needs for backyard fab, you can do alot with them and awesome value. they are only a minor pain when cleaning up 50 lobster back cuts, but you can get pretty quick at it with time. Ill spend up big on a bandsaw when i run out of other cool tools to buy..
I use all three, definitely the Brobo if you can find a cheap S/H one. I also use the $1200 H&F bandsaw for larger sized pipes, great for 4 inch or larger.
I use the friction saw very rarely. It doesn't cut straight and the clean up time is horrendous. If you plan to use one, you will need to invest in a linisher to clean/flatten the cut.
Is this all because alloy has to fit perfect to weld or you get holes n stuff?
I know with steel you wouldnt need a linisher to get it that perfect for welding.
I just got a cheap mig welder and havent tried alloy yet, so im curious.
If your fusing with stainless as most ppl do for cooler piping yes you need a perfect fit to have a nice weld.
tbh.. my cut off saw cuts very straight, 3mm blade (maybe just lucky), only clean up i do is a quick linish and its ready for a perfect fuse with the tig. i posted a few pics in the lobster thread, all that is with the cheap saw.
Yeah I also agree aswell my cheap shitty drop saw cuts pretty straight just have to linish with a grinder and die grinder and they fit spot on.
never had one catch pipe, i dont usually do much alloy pipe work though. I always thought it was a bad idea to cut alloy pipe with a drop saw, the alloy clogs the disc. Dont know how much truth to it and i havent really done much research of my own but was told this can cause the disc to explode in extreme cases.
opps read you use an alloy cutting disc, never mind if you have one of those :)
Edited by r32gtrs
Don't know what horizontal you had in mind, the ones I've used only had variable feed set up for steel and would be horrid for bends, a variable vertical would be my preference if you only had one choice (along with a selection of tooth count blades). Typical stainless tube cutting, I use a friction drop saw as first preference. A disc linisher is very useful for squaring, don't know how good the hobby grade H&F ones are? If all else fails, hacksaw and snips have saved the bacon many times and a realistic option if you're only doing a few!
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
