Never tried tungsten on stainless
I'm using Milwaukee ones at the moment and they are unreal for going through alloy but any bi-metal ones would be fine don't even try to go through stainless with them
No offense. But you are doing it wrong if you cant do stainless sheet with a bi metal hole saw
It really depends on the grade and quality of stainless, and how good the holesaw is. It's a good way to damage your arm if it isn't in a drill press, as the kick on a holesaw when it grabs with a hand drill is harsh.
I have new drill bits here that just polish the stainless, due to the stainless being harder than the drill bit. Cobalt drill sets are definitely worth the coin.
Tired it a few times on a couple heat shields I made for vls with the gate welded on top of the manifold and doing one cut with the bi-metal hole saw killed it yeah I got through but destroyed a $80 holesaw in the process much easier doing it with the hydraulic punch if your cutting through sheet less then a mm yeah go ahead but 2mm plus your just throughing your money away
  • 2 months later...
We were in a pinch once and use a builders wood saw to cut some alloy intercooler pipe. worked so well we have done it again. Cuts fast and straight, much straighter than a hack saw anyway haha
If you use a bit of wd40 or light machine oil as lube, a carbide tipped blade on a timber cutting drop saw works perfectly.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
