Hi all,
Looks like it might be time to sell the M35 unfortunately, so just putting it out there to gauge interest...
Here's the details:
2002 NM35 250t RS Four
88,000kms
QX1 white pearl
M35 Dayz bodykit & rear spoiler
Impul ECU
Blitz NUR 3" stainless steel catback exhaust
Heatwrapped Scotty dump & catted mid pipe
Inlet runner spacer
Blitz panel filter
HDi front mounted intercooler
Turbosmart plumb-back BOV
2 x oil catch cans
Transgo shift kit
LSD rear diff (no HICAS)
Tein coilovers
Whiteline front & rear swaybars with HD rear links
Daleobrace front lower chassis brace
Ox Motorsport rear chassis brace
SPC rear camber & toe kit
Hardrace adjustable front upper A-arms
Superpro front caster bushes
350Z 'Track' Brembo gold calipers with QFM pads & slotted DBA rotors front & rear
Gloss black 19" x 8.5" Rota Grid wheels +25 offset
Engine oil cooler & power steering cooler
Scotty coolant bypass & bleed valve
Nismo thermostat
Samco silicone radiator hoses
Boost, engine oil temp & pressure, transmission temp gauges (factory triple gauges also)
HKS OB-Link hooked to 6" Android tablet mounted in factory pop-up screen location
Alpine Double-DIN touchscreen DVD headunit with Bluetooth & Satnav with reverse camera
DTV-B TV Tuner using factory antenna
Brake wire cut mod with switch
Recently replaced O2 sensor, AFM (old p/n), front lower ball joints, front hub bearings, rocker cover gaskets (both), Philips D2R headlight globes, battery, Attessa pump
March '14 rego
Will have to take some more pics I think...
https://www.sau.com.au/forums/topic/432605-eoi-om350/
A mate at work is looking for a new car and we are trying to talk him into getting a stag, ill show him this tomorrow and hopefully he'll check it out if you haven't sold it already. If I had the cash I'd just buy it and have two! Palm my shit-spec one off to the Mrs.
https://www.sau.com.au/forums/topic/432605-eoi-om350/#findComment-7074706
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
