Wanted: R33 Skyline Series 2 Gts Return Bov Pipe
Err stock BOV return line is metal.
Well, I assume he's talking about the short bit of rubber (2-3inches) that joins that metal pipe to the metal outlet of the BOV?
I think I replaced mine with a silicone item, and it's just a straight piece. If that's the bit you need (OP), just go to an auto store and buy the right ID size pipe, (sold by the metre usually) and cut it to size.
If that fails, go to supercheap or some shop like that an look through their pile of radiator hoses. I'll bet a small car uses something that size for coolant or something.
If you have the standard GTST BoV use a straight silicone joiner 28mm. If you've got a GTR BoV get a straight reducer 38mm to 28mm. Search ebay theres a guy in Sydney called ProFlow or something
Granted, except they asked for "After return pipe from BOV to turbo inlet for series 2 skyline GTS-t urgently."
A short piece of rubber isn't a return pipe to the intake.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
