Where can these missions be found?
I can only find stupid 3k missions that I get on my mobile.
I know Violent Duct is unlocked from Gerald at level 15.
I can usually make about 50 grand in a 2-3 hour session, just do missions when they come up and remember to sell a car to Los Santos Customs once a day. Head into the area around Michael's house and look for the Quattroporte convertible looking thing, should get $9,500
swweet.
good advice to follow im on it.
Omg sucks reading this, I wanna play!
Called my Internet provider up, said my Internet should be fine by 4pm Saturday..
It's now 1:15 and its still capped and won't load!!
Been playing at my mates houses but their net is slow and gay... :(
Cars can be sold to Los Santos Customs every 48min IRL / 24hrs in game. Thats a good way to make coin.
No Hay Bronca and Violet Duct are both missions by Gerald (The suss looking bloke in the suss looking apartment that says nothing but "Aight" or "Yeah")
hahah!
kinda getting over the "go get this, get shot at, bring it here" missions though, but i guess that'll change as i go further - i can visit lester now yay
you think? i dont see many heists and that going down. i think its gonna be much of the same.
i'm reallllly hoping that as i level up further there'll be actual heists... what i also want is for when i'm doing a "story" mission, for it to not ask me if i want to do some random f**king race or mission (take my pick) afterwards too, which I then always choose freemode anyway... :/
ok looking at videos - looks like you gotta buy a house first to set up heists
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
