sounds exciting, should be online by the time im back home from the gym tonight. can't wait.
ok so i have barely (i.e. not at all) investigated what is available online...can we somehow decorate our house (if we get one)? Like spray paint our logo over it?
also racing(fighting) the evo/sti guys, i think we might need some kind of organisation at least to find where they are so we can trash their clubhouse meet up with them
  • Like 1
i really wanna get digging into the editor - it looks fairly easy to use, although all i've seen is from the video about making missions etc.
I'll need to have a good look into what's available, but what kind of missions are people looking into doing? I'm keen on races and heists, but does anyone want to do team deathmatch etc?
i down for abit of everything. to be honest, im least likely to do car races...... but ill give em a go.... i wanna try and do as many as the 300 online missions as possible.
I'm all for completing missions with the SAU crew and will support where necessary.
However, I really can't wait to cause havoc to the other crews. Build up relationships/trust and when they least expect it, f**k them up :)
Good ol' GTA - letting us do things we wouldn't normally do in real life since the 90s.
damn straight...... i dont really care what you do.... but if the other members are getting hammered because of your mistakes, you may find a horses head in your bed.
Excellent! I would be disappointed if it was any other way.
Massive nights in strip clubs anyone?
This is a must!
Just a warning, these kind of nights will end with a murderous rampage in the strip club. Anyone is free to join in on said rampage.
  • Like 1
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
