Oh and for the guy who was swapping in and out of passive mode to kill/troll people...I tried that...as soon as I disabled it I couldn't access weapon wheel for 10 seconds but the guy I was following could shoot me on foot. It must put you out of passive mode for other players straight away, but you have to wait.
Also people with tanks are starting to get really annoying.
was me,
they didnt figure this out when i was doing it, probably becuase they were trying to ignore me i guess
was me,
Yeah if they were noobs or stopped looking at radar try probably wouldn't see, but I tried to get the sneak on this guy, within 2 seconds of changing it he'd turned around and popped me with sawed off.
That's why you go in the distance, wait the 10secs after passive mode pull out the rifle and pop to he's head.
Just bought the $19 bluetooth headset from kmart. Looks pretty neat, hope it's good.
That's why you go in the distance, wait the 10secs after passive mode pull out the rifle and pop to he's head. Just bought the $19 bluetooth headset from kmart. Looks pretty neat, hope it's good.
Doesn't work that well if he's got an awareness for you. Soon as that white full circle shows on his radar he has 10 seconds to eliminate you. Really gotta get lucky with it and hope someone is stupid cause it backfires easily.
I've got this PS3 headset (it's SOny OEM) and it works a treat! Battery life is not that great but it'll do about 6 hours. The best thing is it's 7.1 full surround...
Oh and i'm in for 8pm Thursday on PSN :)
And my garage....
http://rsg.ms/1b7cy05
Thursday at 8 I thought was the plan?
Private SAU session. Winning.
Not sure what to do with those of us who dont have Mic's. Might see If I can get my bluetooth keyboard to work with the PS3 again
im down for this....i got no immediate plans tonight
So, currently I'm OK with being on at 8 tonight, It's easy to set-up a crew only session, the only issue is that the host needs relatively decent interweb speeds. Since its crew only, the crew heirache determine what you can and cant do, so its not an issue if a higher rank isn't host.
In single player, go to On-line in the pause menu, then "Play GTA Online" and select "Closed Crew Session", so only members of your crew can join. If there are crew members already online then send out a crew invite. If you login after its made and dont get auto joined, use the join other crew members function.
I'm happy to host if its not set-up by the time i login should be home 6ish online by about 7 maybe. I think my PSN is ianjb - if not, it will be pyroib
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
