haha, yeah i was fooling around trying to get a decent car, some asshole smashes it out from next to me and knocks me over, gets out, pulls his gun so im like f**k that, bam bam bam!
starting to think that making a Teamspeak server might be good - f**k off the ingame chat and use something that's crew-only :P
  • Like 1
i need 360 guys!
im a proper billy no mates.
all the people i team up with for missions are shit and i end up doing it all my self, and getting an equal share of the kesh.
which is bullshit.
hit level 7 last night. im now a crew monkey.
theres a crew-only chat setting in the main menu under audio. farkin lifesaver.
did some racers with manuel. it was pretty fun (i hope it didnt look like i rammed you into oncoming traffic with the dirt bikes :P, it wasnt intentional)
so far made a little bit of money and almost level 6. So far spent about $15-20,000 on tatoos. still a lot to unlock and dosh to spend.
Haha Leroy that was a classic when I just went head on into the car. Your guy looks proper bad ass with the tats and no shirt. What's the go with the head phones lol
lol Dr Dre headphones are for gimps, my guy only wears proper ear muffs haha
+1 for shirts being too expensive when saving $5000 for a single tattoo :P
I want that much money! lol
Sounds promising for wednesday when I get home. Should have half decent online gameplay by then. Then I have to start playing F1 2013. Why can't they bring games out at different times!
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
