Hi,
I have just recently got myself a Stag (WC34 S1 - 1997), something practical for having a family and what will be a bigger dog when its grown up.
There are a few things on it that need changing and/or fixing.
The speedo and rev counter don't work, the speedo sits on 20km/h and the rev's just sit near zero flicking, has anyone had this issue and know what the problem is and how to fix it ?
And what globes do the parker lights take ? Mine has bluer ones in them at the moment and as far as I know, cops don't like that.
And does anyone have a stock exhaust, and how much would you want for it (in SA) ? The current one is loud and as I am just looking more for it to be a family bus, I don't really want it to be loud and don't need the attention loud exhausts bring.
Thanks
Edited by Direwolf
https://www.sau.com.au/forums/topic/432614-new-stag-owner/
have a go at removing the dash and cleaning all the connectors...? i think it's a cheaper option (than repairing) if you buy a second hand dash unit. i may be wrong.
as for your parker lights they should be T10 wedge LEDs, ebay is your best friend here.
https://www.sau.com.au/forums/topic/432614-new-stag-owner/#findComment-7046542
I chucked my stock exhaust a few months ago! You can make a decent flowing exhaust quiet with the right type of mufflers, mine has no cat and 3 inch whole way, one Hooker aero chamber and a berklee straight through at the rear. makes qround 300rwkw and tests at 87db at 3000rpm so its legal. the mufflers cost around 250 foe both from memory, just get them put in.
https://www.sau.com.au/forums/topic/432614-new-stag-owner/#findComment-7047486
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
