Ok this may be a repost i dunno but has anyone seen the MTT Superbike?
This thing is NUTS!
Here are the specs.....
Engine:
Rolls Royce Allison
250 gas turbine
Power
320 HP @52,000 rpm
(286 HP @ rear wheel)
Output RPM:
6,000 rpm
Torque:
425 ft/lbs @ 2,000 rpm
Compressor Speed:
54,000 rpm
Fuel:
diesel, kerosene
Lubrication:
dry-sump/3.5 quarts turbine oil
Transmission:
2 speed automatic or manual
Rear Mirrors:
rear mounted camera with LCD color
display plus rear view mirrors
Options:
single or double seat, custom colors
Frame:
aluminum alloy
Rake:
27 degrees
Weight:
500 lbs
Seat Height:
31.5 in
Wheel Base:
68 in
Wheels:
17" carbon fiber, Dymag
Tires - Front:
120 60ZR17, Pirelli
- Rear:
200 50ZR17, Pirelli
Front Forks:
55 mm inverted
Shocks:
mono-shock adjustable
oleopneumatic, Ohlins
Brakes:
3x320 mm floating system- 4 piston
calipers, Brembo
Fuel Capacity:
8.5 gallons (34 liters)
Radar Detector:
forward and rear-looking radar
with laser scrambler, K40
I have a link for the short video of one starting up will post the link 2morrow if people are keen to have a listen
https://www.sau.com.au/forums/topic/43262-omg-mtt-superbike/
