hay guys i have a problem and for the life of me cant find the cause
car is a s1 r33 one morning i came out and started the car started fine as u usual was sitting there idling getting ready to go and it just stalled would turn over but not fire. Traced the cause of that back to the coil packs i have lost my 12v to the coilpacks, for the time being i have tapped into the 12v on the side of the engine bay and it starts perfect(will this hurt anything by the way?) but cant seem to find out why the 12v in the loom has gone. Is there a fuse for that specific 12v to the loom or could it be something else ?? any help would be much appreciated cheers guys.
https://www.sau.com.au/forums/topic/432635-r33-12v-to-coilpacks-is-gone/
sorry should have added this before the loom on my car has been changed to a s2 loom and coils and as i said the car was running fine before so i know its not the wiring on that thats the cause ??
Try looking at fuse number 3. It feeds an ignition relay above the ECU that pulls in when the ignition is turned on and sends the 12V to the coil packs.
There are a few 12V relays just above the ecu in the passenger kick panel. Can't remember if its the blue or brown one. You should here them click when you turn the ign on
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
