/Sold GTR parts to 24 different people.
Try to sell more claiming I have sold a whole car off.
Told I couldn't have because I only have three people who've given me feedback.
Yeaw.
Anyway.
Got more shit to sell guys.
Pic of all items:
1270624_645091675535877_1492568459_o.jpg1291882_645091735535871_1199280826_o.jpgPics don't show carpet, nor sumitomo 4 pot calipers.
Parts + Prices.
Wing Mirrors - $30 each. (One has mirror separation, the other has fade, both work fine.)
149xxx odo, excellent cond. - $120
Drivers and passengers kick panels - $30 each.
Immac. Rear view mirror - $30
Fuse box cover, mint (Jap) - $10
Inner mirror covers (doors) - $10 each.
C.A.S Alloy bracket - $50
Coil packs on rails - $100
Drivers side lower vent, perfect nic - $15
Lower dash panel (covers fuse box, etc), immac. - $30
Door kick panels, good nic - $10 each.
Rear lower passenger trims - $40 each (One is missing the foam fabric insert, I do have it, it is also in good nic, just came off.)
Passenger A-Pillar trim, immac. - $20
Front lower guard "pods" - $25 each
Stock AFMS (working) - $40 each.
Dash temp/light sensor - $10
Rear eye-level brake light - $25
Indicator stalk and mechanism - $40
I WILL POST.
I would PREFER you pick-up and pay in cash though.
ALL ITEMS IN GOOD CONDITION UNLESS OTHERWISE STATED.
PM ME. or Text: 0431045486.
Posting here will not be seen.
I will accept all reasonable offers, as all parts are priced reasonably.
If you turn up and expect to buy $350 worth of parts and say you only have $200 YOU WILL BE TURNED AWAY. Parts are well priced. Thanks.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
