/Sold GTR parts to 24 different people.
Try to sell more claiming I have sold a whole car off.
Told I couldn't have because I only have three people who've given me feedback.
Yeaw.
Anyway.
Got more shit to sell guys.
Pic of all items:
1270624_645091675535877_1492568459_o.jpg1291882_645091735535871_1199280826_o.jpgPics don't show carpet, nor sumitomo 4 pot calipers.
Parts + Prices.
Wing Mirrors - $30 each. (One has mirror separation, the other has fade, both work fine.)
149xxx odo, excellent cond. - $120
Drivers and passengers kick panels - $30 each.
Immac. Rear view mirror - $30
Fuse box cover, mint (Jap) - $10
Inner mirror covers (doors) - $10 each.
C.A.S Alloy bracket - $50
Coil packs on rails - $100
Drivers side lower vent, perfect nic - $15
Lower dash panel (covers fuse box, etc), immac. - $30
Door kick panels, good nic - $10 each.
Rear lower passenger trims - $40 each (One is missing the foam fabric insert, I do have it, it is also in good nic, just came off.)
Passenger A-Pillar trim, immac. - $20
Front lower guard "pods" - $25 each
Stock AFMS (working) - $40 each.
Dash temp/light sensor - $10
Rear eye-level brake light - $25
Indicator stalk and mechanism - $40
I WILL POST.
I would PREFER you pick-up and pay in cash though.
ALL ITEMS IN GOOD CONDITION UNLESS OTHERWISE STATED.
PM ME. or Text: 0431045486.
Posting here will not be seen.
I will accept all reasonable offers, as all parts are priced reasonably.
If you turn up and expect to buy $350 worth of parts and say you only have $200 YOU WILL BE TURNED AWAY. Parts are well priced. Thanks.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
