I've been chatting at work to a bloke who's got a damn good mind!
I want to know if there is a sensor avaliable to show pressure in and electronic signal?
We want to put sensors before the turbo(s); between the turbo(s) and the intercooler and between the intercooler and the inlet manifold (or in manifold, which ever is easier)...
What, how etc etc?
Any thoughts/ideas etc?....
https://www.sau.com.au/forums/topic/43271-tech-heads-need-some-answers/
http://www.autospeed.com/cgi-bin/browse.cg...oduct=888800079
Pressure/Vaccumn switch, basically it won't give you a measurement, but you can make it trigger at certain pressures.
its a start, it also has links to some articles that might give you or your mate some ideas.
Bass Junky, permanently... We wanna rig up a digital display that shows what the air goes into the turbo at; what it comes out of the turbo at (turbo effieciency or whatever you call it) then what it goes into the manifold at (ie what loss is caused through the pipes and intercooler etc....
Don't really wanna spend a fortune converting the car to MAP for that you know?....
just need 3 lil sensors that we can plumb into the pipes to send the pressure as a digital signal....
Does that help?
You dont need to convert the car to MAP based management...
A map sensor is a small, relatively cheap device that converts a pressure signal (ie from your intercooler plumbing) to an electrical signal...
Stock 33 boost guage is driven by a MAP sensor...
funky, I had a look at that and it looks good too...
I was just picturing something cheap and simple that could be tapped into the pipes like the O2 sensors in the dump pipes.... any thing like that? is that what a MAP sensor would be like?
Permanently: You would then have to weld little lugs to the places you want the signal to be taken from and then attach a MAP sensor to each lug.
From there you would have to output that signal to some sort of display unit.
I can't really see this as being a cheap thing to do......
The alternative it to plumb up three seperate boost gauges....
I think Autometer now have digital readouts which have the outputs from two sensors displayed on the one guage. You can configure them to be whatever you want. (might not be autometer.... but it's someone.
BASS OUT
Yeah, the drilling/welding shouldn't be too expensive if we know a welder though should it...
We're going to design our own display unit, using the 3... so the 3 boost guages would be a waste of money....
So how much do you think it would be for the 3 MAP sensors?
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
