Lol well we've heard from dumb and as usual sniffing his arse we've heard from dumber, Wardy I think we all know you're king of the hand jobs, every night out in your carport with your dick in hand! Just saying :P
Every time I read posts in the R35 section we reach a new level of stupidity...... I do wonder what is really going on in their life and minds when they fell the need to write this stuff?
Agree
Spot on Brian.. How puerile, explains why the SAU Site isn't frequented much by R35 Owners.
Hey Mark,
Who'd you end up getting finance through?
I didn't end up going with Finance. So much headaches to go with finance i worked out i would pay an extra 20k for the car over the next 3-5 years on interest rate of 5.1-6.0% ... so decided to put those savings into mods.
however based on the finance hunting experience:
Aussie Car Loans - avoid they are useless no follow up calls and poor customer service
Banks - not willing to give you any sort of good rate so avoid
360 Finance - best customer service and best rate end of the day.
Sratton - previous owner was with them and had a very good rate with them (5.2% or there abouts) and he spoke highly of them.
Also one thing i didnt know but try to avoid shopping around too much for finance, as apparently if your credit file gets accessed or "hit" too many times in a short period of time this will actually be a negative thing in the lenders eyes as they see it as a risk as to why you are trying to get finance from so many different places....
Edited by BLISTC
Cool. At car rates it's a tight call between cash and finance but cash avoids a lot of headaches.
You only get a "hit" if they actually do a VEDA check. Just enquiring about rates and doing calculations doesn't trigger that. It's only once you actually submit an application they run the check.
By Sratton I assume you mean Stratton Finance? They are one of our groups; a good bunch of guys and gals.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
