Nice man good idea will get onto that.
Just bit sure how much fuel she is going to use. Very much a gas guzzler now.
My drum arrives this week at some stage.
Sounds like it would be a pretty car to ride in... Just sayin :P
This list will be updated as the organisers provide me with more info incl time and location. It's on the first page.
North Side: Twin BPs at Caboolture, Clint (RandomHero83)
South Side: Scott (Sabbai)
East Side: Dan (Cyifly) and Ray (raysboostin)
West Side: Chris (olloSkylineollo) and Nick (Captain Natro)
If there are any BNR34 owners here that are going and arent a part of the fb page (you will know if you are), please PM me.
Noy mentioned that he will try and grab a few of the R34 guys as well. Should be a great turnout!
Was guna bring along a m8 in my car, is he required to pay the $20 and a toy or is that a per car cost?
havent been on QR yet either guna try to get to the one next weekend but not sure if i can, if not no go in sprints at lakeside?
It's per car, but it's for charity so any additional donations would certainly be welcome!
Sprints are run by QR not by the club, and there is no requirement for doing QR before lakeside or anything like that. However, I'm not sure if the people coming on the cruise will get to lakeside in time to enter the sprints as well:
Hopefully about 12-12:30. I think it will be cutting it too fine to be driving in the sprints.
Also, my personal recommendation is to give QR a try before doing sprints at lakeside, lakeside is dangerous. It does depend on your track driving experience though...
Everything that Martin said :P
We most likely won't be at LP in time for the driver breifing so you may not be allowed in the sprints. On the other hand, we have a heap of sprint days arranged for next year and you can do them once you get a bit more track time under your belt. ;)
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
