Re post with updated list and because the old post is locked. Not sure how to unlock it either!
CONTACT NO: 0432 544 363
HUGE bunch of R33 GTS-T parts for SALE!
Engine bay / bolt ons etc:
- Standard Intercooler piping $40
- Standard turbo $150
- Standard Airbox with snorkel $150
- Standard cross over pipe with BOV $50
- Standard RB25det series 1 loom & ECU $100
- Turnflow intercooler kit with piping $150
- Copper radiator $80
- Alternator $50
- A/C compressor $50
- Power steering pump $50 SOLD
- Starter motor $50
- Engine mounts $50
- Rb25 Clutch fan $50
- CUSCO catch can $80 SOLD
- Strut brace in Cusco blue (unsure of brand) $50
- Dump pipe / Front pipe 2.5" or 3" $40
- JASMA 3" exhaust mid muffler is damaged $80
Drivetrain components:
- Complete manual conversion to suit R33/R34 $1500
- 5 Speed gearbox $1000
- Clutch master & slave cylinder with fluid reservoir $80
- Xtreme Heavy duty clutch & Flywheel $250 (<1000kms old)
- Tailshaft $100
- 4.11 LSD diff $150
- 5 Bolt half shafts $100
- Rear subframe (bare) $50
- Front subframe (bare) $50
Suspension / arms / etc:
- Standard steering wheel $10 with horn (rough)
- Standard suspension $100
- Standard Front Upper Camber Arms $40 pair
- Standard Front Upper Lower control Arms $40 pair
- Standard Front L/R Castor rods $50 pair
- Standard Rear L/R Camber Arms $40 pair
- Standard Rear L/R Traction Arms $40 pair
- Standard Complete 5 stud conversion including brakes $500
- Standard Sway bars F/R $20 each
- Steering rack $80
- Steering column $20
Exterior
(all parts are (QM1) Factory white paint code)
- Headlights $200
- Bonnet $20 (hail damaged) SOLD
- R33 series 1.5 bumper with reo & indicators $200 REO SOLD
- Doors $80/ Each (complete minus mirrors)
- Guards 50/ Each
- Standard side skirts $150
- Rear view mirrors $50/ Each
- Rear tail light with housings $80
- Skyline centre garnish $20
- Rear bumper $50
- Sunroof $200 (with roof lining and everything to make it work) SOLD
Interior
- Non airbag clockspring $40
- Dash fascia with vents, hazard, demister etc $80
- Climate control $50
- Indicator stalk $15
- Wiper stalk $15
- Steering column surround $10
- Skyline Door Scuff Plates $20 pair
- Sun Visors $20 pair
- Dashboard $50
- Heater core $30
- Blower fan & A/C core $50
- A/B Pillar trims $30
https://www.sau.com.au/forums/topic/432763-wrecking-r33-gtst-heaps-to-go/
SOLD - Turbo, turn flow intercooler kit, PS pump, clutch fan, catch can, dump pipe, clutch master and slave cylinder, tail shaft, sunroof, clock spring, dash fascia, indicator stalk.
Everything else still available!!!
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
