Need help in this guys. Was driving normally a few days ago and suddenly the light comes on in dashboard. Gears limited to 1 3 5 but not top speed limit. Talked to a few people and was told that Dodson and Willall both supply the sensors to fix the issue.
Problem is, I am from Melbourne. So it comes down to only two choices:
1. Tow the car to either Willall in Adelaide or Just Jap Auto (Dodson dealer) in NSW. This way is safe but I have never towed a car to other states. Obviously cost factor is going to be higher and its also troublesome somehow (I am really busy).
2. Purchase the sensor part from either Willall or Dodson and find a skilled local workshop. But I have no idea who has experience (thats why i am asking...) or should be skilled enough to have their first go. I favor this more as it would make my life so much easier.
So, I am hoping if anyone here could give me some advices... Pretty sure I am not the first person who encountered this problem in Victoria and hopefully someone could share their experience with me. It seems to be not the end of the world job and just need a skilled workshop to change the plug and play sensor (if I am not wrong from my research).
Got two questions here:
1. Does anyone know how the job is done? Drop the whole gearbox or just part of it? Gear box oil to be flushed as well? Any others?
2. Is there anyone who has done the fix in Melbourne? Was it successful? Where was it done? Cost factors?
3. Is there anyone who has towed their car to Willall from Melbourne? Around how much was the damage in dollars including the labour, parts and towing fee?
4. If by any chance I am going to try to do it in a work shop in Melbourne? Any recommendations? MPC? Techsport?
Would appreciate any type of input. As any of you could imagine I am quite panic on this matter. It sounded like doom day at the start as I heard the whole gearbox needs to be replaced (dealership way of handling). But good news was its just the sensors, however where to fit the sensors also sounded like a pain....
Thanks a lot in advance!!
https://www.sau.com.au/forums/topic/432774-p0840-pressure-sensor-fail/
Yeah Limp mode sucks, I had the same problem resulting in the box being removed and it turned out the pressure sensors were fine. It was the insulation on a wire inside had frayed resulting in the faulting. Over $3,000 later I was back on the road... (GTR tax)
If you are pulling the box out I would recommend checking/upgrading the other small things that can cause problems. Dodson are all over these things. Makes sense to upgrade once
All the best
All the best
Thanks for the input. Which error code did you get? As far as i know there are a few different error codes that results in limp mode and some even have limited top speed. Just trying to see if we are the same situation. $3000, yea take it as GTR tax. Just hope that it doesnt get larger than that...
Thanks again!
  • 1 month later...
Just an update and conclusion. Went to Racepace for it at last. Took about 1 week including to wait for parts etc. This is a list of cost break down:
1. Dodson sensors x 3 and kit (although only 1 failed I decided to change all 3 just incase the other 2 fail) $1200
2. Labour $1500
3. Gear box oil refill (depending what oil u use)
So all up about a mid 3 grand to high 3 grand fix.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
