Ok guys the other nite I had fitted up my plazmaman fuel rail along with the 1000cc xspurts mounted a new magnafuel fpr, re done all the fuel lines. Got the car running but I've got a humming/buzzing noise is coming from the fuel pressure reg. if you hold the reg u can feel it. The noise is quite loud and really annoying. I've played around with the fuel pressure between 30-40psi and the noise changes as you go up In pressure. Any one else come across this? Is it just the pulasation from the fuel pump? The buzzing noise was never there with the factory fuel rail and reg..
If there's no fix for this ie changing the fuel dampner with another one from a different car ill have to change the reg its far too annoying.
What regs are use using that are e85 friendly? Cheers
All regs will make some noise, mainly at idle, especially high flow aftermarket ones. What pump are you using?
You could try rubber isolation of the reg, or fitting the stock dampeners back into the fuel system? I use an SX reg, it has been perfect for many years on ethanol.
Currently it's a walbro 255 intank. The reg was hard mounted and I thought of rubber mounting but even with the reg removed and holding it in your hand the sound is the same. I was reading up else where that after market regs have a stainless needle and seat and pulsations from the fuel pump and injectors opening and closing can make this chatter. What's got me stuffed is the factory fuel damper is still installed but in standard form from the factory, the fuel damper is down stream after the reg on the return line. I thought you would want this installed either after the fuel filter/before the fuel rail, or after the fuel rail and before the fuel reg so the pulsation damper can actually absorb some of the pulsations from the fuel pump and injectors..
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
