i've got 33K saved already... yeah ive seen eriks r34 very nice but i really wanted a white or yellow one though. i dont mine waiting 3 or 4 months as ill be buying at the end of the year anyway so i can save a bit more dough.
ive only seen manual r34 for 40K+ and auto for 35K so eriks is quite a bargin.
Does anyone know any dealers etc...
extreme machines is a good place to test drive a r34 but to buy is absolute rip off...
import is the best way but waiting is a bitch i went through prestige motorsport to get my car and am waiting on the arrival of it but geoff frfom prestige has been most help full with every stupid question i ask plus he is perth based...
it is a much cheaper allternative to import and he can help you find any colour and mods you want for your budget......
R34's are avialable in the eastern states and will be avialable any day now here for dealers and personal importers as a couple are sorting out vehicle inspection, I know of one who will help you buy a car free of charge if you buy a plate off him and yes the price is the same as everybody else.
Dont bad mouth peoples prices either if you dont like it keep it to your self and dont post it.
www.j-spec.com.au is also one of the guys who started it off and he buys grade 4 cars that can be inspected as you dont want a damaged car as a couple have to be exported already.
Talk to local RAWS who have R34 compliance as the DOTR's site is updated daily or do research as the first post web site is just cut and paste of cars in stock that have already been bought so imagine what the real price is.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
