My car has started blowing blue smoke only on boost when I give it a little bit. The turbo makes a very odd whine hiss spool in vacuum and can hear it makin this whine once the car shuts off for a second. It also is quite laggy considering stock turbo. I took the front piping off and there was like a thin film of oil in it and the shaft play moves in and out about 1-2mm. I did a compression test and got 150, 150, 160, 140, 160, 160. Number 4 cylinder had gunk In the thread and it didn't tighten in fully. So compression is good. It also runs mint, apart from being a little laggy and sluggish.
https://www.sau.com.au/forums/topic/432818-rb25-turbo-seals/
I blew rear seal on y turbo - it would blow blue smoke in the mornings (cold start) and occasionally if I jumped on heavy boost... :(
For the price of a high flowed turbo, getting a second hand one seems like an unnecessary gamble.
A proper highflow with increased power rating could cost upto $2K, depending on where you get it done... For something cheaper yet reliable (from what I've read), hypergear has some good highflows!
hyper gear high flow is a proper high flow!
  • Like 1
Im in a similar boat to the OP. Im getting a standard hypergear high flow done as an alternative to buying a second hand neo turbo. It was only a few hundred more for a turbo you know the full history of, since its "new". I wont have it back into the car until a few weeks, so until then I have no opinion on how it functions.
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
