Mt Glorious And Mt Mee - Labour Day Weekend
Got this from another forum i belong to..
"Anyone planning a quiet drive up Mt Glorious or Mt Mee this coming long weekend. I have been told on VERY good authority that there will be a large number of People in Blue Uniforms and DOT check stations established in these areas"
Thanks for the heads up!
"Anyone planning a quiet drive up Mt Glorious or Mt Mee this coming long weekend. I have been told on VERY good authority that there will be a large number of People in Blue Uniforms and DOT check stations established in these areas" [/size]
that would be because of the 2500 motorbikes who will frequent the hills any given weekend...
Its one entry and one exit, so no running...
They had a dot station at the top of Mt G last weekend, took about 20 bikes off the road in the hour i was there having coffee...
  • Like 1
Could be doing what I am at the moment. Chatting with QPS and DOT about legal mods.
Organised meet at strathpine shops underground car park next to McDonalds.
QPS are friendly and NOT taking notes.
Whens this?
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
