That's my old boat mate, the box was the standard R33GTS t box, it was rebuilt and modified not that long ago, if its at UNIGROUP now they can tell you about the internal mods, but after the rebuild it did about 20 runs with drag radials which may have upset it again.
I was going to get a better box but instead got a better school for my daughter, LOL.
Don't go off the old dyno sheet that was supplied with the sale, that sheet was taken at UNIGROUP by Stevo during the tuning, it was detuned from there to keep the tune safe as the fuel flow was wanting due to injectors being on the small side, when it left it was running about 380, it will be a totally different beast on E85 with some more boost and tuning.
It should go well with a good fuel set up, it ate nearly everything at the SAU nats for speed and was the fastest and quickest RWD by far, the trophy's are somewhere at UNIGROUP.
Best time at the strip I got was 11.080 @ 132? mph, I want you to get it well into the 10's.
As for the track, now it has a new nut behind the wheel the times should drop there as well.
Tell me when you go and post results.
I also found in the bottom of my toolbox most of a copy of the user manual if you want it, it was sold with one originally with all the spares, its yours if you want it, but only pages 49 to 144.
Good to finally speak to you mark really am glad umm yeah there car is at uni group as we speak I have the trophies as well they speak highly of you and the boat lol. It getting a whole new fuel system 5 litre surge tank internal x2 wall bro pumps flex sensor 2000cc injectors fuel rail control sensor etc. whole new dyno and map... I will definetly be posting all results.. And will more then likely be taking it to creek this wens if unigroup are done I honestly can't wait the car is my pride and joy... The car has got some sort of manual with it a copy.. You have the original is that what it is or
Do you have the drag radials that I sold with the car, if so they are getting very old and like a big burn out to bring them on.
I think it liked to launch at around 4000 rpm if I recall, less than that it bogged down and any more it just spun, I suppose it will be different with a different tune?
Have you got a Super Street ANDRA licence, if you don't expect to get kicked out the first run the car hooks up, or you can pay for SS licence on the night for $150 or something, they will hit you up at the slip office on your way back .
If you are planning on going more than once you WILL need one.
Its fun beating almost every rego'ed RWD & 4WD street car at the drags (not trailer queens with rego plates that wouldn't pass a pink slip), my favourite win was against some Porsche 4wd turbo thing that cost $300,000, he complained that he didn't have the launch control on, we lined up again and I beat him again, he did have me till half track though, but at half track I flew passed him, laughing .
Ummm yeah I do have them radials he sold them to me with the car they look a bit how you going I'll try them out for the first time plus I just bought 4 brand new rs3 hankook tyres costly but I like them... License wise I plann to get a good time and that's probably it don't want to put the car under a shit load of stress ATM but then again that can all change as I probably just going to keep chasing better times...plus I only had 3 points of my license left and got pulled over in it a few weeks ago and in 3 weeks lose my license...but when I get it back in 3 months I want to start taking it to the track and stuff.. I'm putting it in a mag soon too I'll let you know how dyno and stuff goes next week..
PM me if you are going to WSID and if I'm free I'll come for a look and bring the bits of the user guide I've got.
If not then I will most likely see you on the street, if a big red BF Falcon starts following you don't worry its only me.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
