Hey mark I just spoke too uni group the boat got 437kw on 28 psi then the turbo started to produce hot air and also had a few minor petrol leaks which they are fixing then it's going back on the dyno I'll be back in Sydney in one week will msg you when I'm taking it too track
The stock box will take the power as long as you have some mechanical sympathy.
I got the stock box rebuilt and modified but at the drags with sticky tyres and sticky track it started to chew the case hardening of the gears after about a dozen runs, the oil I used was good quality, and I even swapped out the oil and added some modifiers to try and slow the wear but to no avail.
When you are pushing a heap of torque the stock box might be fine for street duties or the occasional squirt , but when it gets leaned on it is found wanting.
Disclaimer: This is from my experience of 2 gearboxes and talking to people at the drags, most overcame the issue by installing a slush box.
Hey mark I got the car back from uni group I took it to the runs but was only allowed to drive it on low boost cause the ethanol was not above 60 so there for didn't call u out I take the car back there on Friday for another dyno session car made 437 kW then turbo max out I got an 11.8 on low boost 21psi after they dyno it on fri then she will be ready for hi boost 28psi I need new mickeys for rear I could not get traction what's so ever I should be going next week if not def following week will let you know when she ready 4 hi boost and come down... Quick question I noticed under hi torque and lots off pressure the engine light flashes on sought of off through the gears only under high revs take off and stuff did you ever notice engine light come on and off at all when u owned....
PowerFC? Engine light flashing is knock indication isn't it? In that case, happening at high load makes sense.
Also, try distributing the full stops in your above post around the post a bit more evenly. Leaving them clumped up together doesn't work. I have a headache after reading it!!
Edited by GTSBoy
I got the stock box rebuilt and modified but at the drags with sticky tyres and sticky track it started to chew the case hardening of the gears after about a dozen runs.
/quote]
Our shot peening and Isotropic super finishing would help this situation.
I think the engine check light was set up for over boost warning, its been a while and I cannot remember exactly.
I remember the low oil pressure warning light would come on at idle which was fine as it was set fairly high, it is adjustable if you want set it higher or lower.
oh ok no problem I take it to unigroup tomorrow will check with them. I should easily crack a 10 next run.
    • I'm late to the party on this one but good to see common sense has prevailed and the turbo kit is coming.
    • She's looking good Greg. Colour suits it perfectly 👍
    • I had a look at the FAB9 EFR kit, around $8500 AU before delivery, so add in shipping, installation, consumables and tuning, I believe the price difference would be negligible  And whilst I am paying top dollar at MX5 Mania, if I have any issues with the kit they are local for support,  and from my experience, will happily go out of their way to help, hell, I've purchased parts from them and asked "how do I install or remove parts" and they have fitted a few of them for free, this means more to me than saving a few thousand dollars And yes, 99% of the time I just plod around in the car, that may change once I start hearing turbo whooshy noises, but, as I have 3 family members is the constabulary, even when I'm up it, it is only up to the speed limit, or occasionally, but rarely, overtaking on the Hwy (I just plod in the left lane typically and enjoy the drive) Plus the kids would never let it go if I got booked speeding, Jackie is constantly getting critiqued by the kids about her driving, which I think is hilarious, and tell them that she is "bringing shame to our family", so heaven forbid if I ever got done speeding, after all my mouthing off about her driving, I would never live it down, and it would be another thing she would bring up any chance she got Like the time I got drunk about 15 years ago and fell out of a cab, which gets brought up at least a few times every year since it happened Good times
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
