Hey mark I just spoke too uni group the boat got 437kw on 28 psi then the turbo started to produce hot air and also had a few minor petrol leaks which they are fixing then it's going back on the dyno I'll be back in Sydney in one week will msg you when I'm taking it too track
The stock box will take the power as long as you have some mechanical sympathy.
I got the stock box rebuilt and modified but at the drags with sticky tyres and sticky track it started to chew the case hardening of the gears after about a dozen runs, the oil I used was good quality, and I even swapped out the oil and added some modifiers to try and slow the wear but to no avail.
When you are pushing a heap of torque the stock box might be fine for street duties or the occasional squirt , but when it gets leaned on it is found wanting.
Disclaimer: This is from my experience of 2 gearboxes and talking to people at the drags, most overcame the issue by installing a slush box.
Hey mark I got the car back from uni group I took it to the runs but was only allowed to drive it on low boost cause the ethanol was not above 60 so there for didn't call u out I take the car back there on Friday for another dyno session car made 437 kW then turbo max out I got an 11.8 on low boost 21psi after they dyno it on fri then she will be ready for hi boost 28psi I need new mickeys for rear I could not get traction what's so ever I should be going next week if not def following week will let you know when she ready 4 hi boost and come down... Quick question I noticed under hi torque and lots off pressure the engine light flashes on sought of off through the gears only under high revs take off and stuff did you ever notice engine light come on and off at all when u owned....
PowerFC? Engine light flashing is knock indication isn't it? In that case, happening at high load makes sense.
Also, try distributing the full stops in your above post around the post a bit more evenly. Leaving them clumped up together doesn't work. I have a headache after reading it!!
Edited by GTSBoy
I got the stock box rebuilt and modified but at the drags with sticky tyres and sticky track it started to chew the case hardening of the gears after about a dozen runs.
/quote]
Our shot peening and Isotropic super finishing would help this situation.
I think the engine check light was set up for over boost warning, its been a while and I cannot remember exactly.
I remember the low oil pressure warning light would come on at idle which was fine as it was set fairly high, it is adjustable if you want set it higher or lower.
oh ok no problem I take it to unigroup tomorrow will check with them. I should easily crack a 10 next run.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
