The turbo I brought is modified but I know next to nothing abit it apart from it's been modified, if there is anyone in canberra who could check it out take it for a drive etc , basically tell me what I have got please give me a pm or post an we can go from there, not asking for freebees just seone who is local an knows there stuff.
I'm new here by the way and am looking at going to dubbo to swap a vu ls1 ute for another hot skyline as I'm having a great love affair with my turbo ,my first. Any help would be appreciated an reciprocated , of anyone who's been there an knows what there looking at could tell me what been done to my current, an if it's sooner rather than later advice at what to look for on this 7k or swap in dubbo.
I'm not looking for a handout just an eyes on opinion.
Cheers
Daryl
Hi Daz, Is your skyline an R33 or R32? are you southside or norhtside?
most on here could tell you the bolt on mods from sight
and yes, it would be good to know what the seller advertised.
most list there mods but if they didn't I'm sure some one could help.
pics of engine bay (multiple angles, and the turbo), dash, and underneath at the exhaust and inside wheel arches.
wont be able to tell about the engine internals from external.
Remove passenger side kick panel and there will be an ECU - take a pic.
[Edit] - oh and I wouldn't buy another one just yet. Skylines have a way of draining your money ;)
Edited by Sinista32
Sorry it sat in my yard for 6 months
Photos can do I know it's got coil overs but can they a just hight or just stiffness.
Turbo or injectors or even boost I don't know but the plumbing is first rate I'm told front mount inner cooler.
Just got to find them also how do u post pics
Cheers
Daryl
O 431691940
The on I'm looking at this is the description an it's white body perfect
R33 Nissan skyline series 2 gtst turbo! Hks 3' exhaust front mount cooler, boost tee, running 11 psi very quick car... May swap for a v8 or somthing of interest 0488002609 no over seas buyers!! Has double din DVD player Posted with eBay Mobile also has 10 months rego
Mods!
*3inch hks exhaust
*turbo smart boost tee
*pod filter
*split fire coil packs (only a month old)
* new eridium plugs (also only a month old)
*t3 turbo high flowed to t4
*044 in tank Bosch fuel pump
*new alloy radiator and twin thermo alloy soround
*18 inch rims with 95% tread on front and about 40% on rear
*drift bov
Had to relist as the person didn't show I'm wanting a ute so a v8 6 turbo or turbo diesel ute or inboard ski boat
Thx
Daryl
Nice post Mik, I've never seen that ... worthwhile stuff.
Daryl I'm not the person to help you mechanically, many more in here better qualified than I, but welcome to the world of Skylines ... I'm sure you'll get hooked like the rest of us. Someone once told me that when it comes to Skylines, the more mods you have/do the more time it will spend off the road and the more you'll have your hand in your pocket.
Regardless, enjoy the ride mate ...
Cheer mate thx anyway an the link was helpful but offer still Stands, if you know your stuff and could test drive I'm open to it, my number is there and I'm enthusiastic just never had a Japanese car before nor a turbo , I'm green as
So local opinions or any are appreciated .
Have a great Labor Day holidays guys and lasses.
Cheers
Daryl
Cheers
Daryl
Daryl with the car above that you are looking at, make sure it has a tuneable or chipped ECU
If it doesn't then I personally wouldn't bother. Reason being is that it sounds like a throw together job. If they have been running it like that for a long time then the engine will be pretty worse for wear.
I spoke with the guy yesterday he has current Dyno
Papers for the car getting 254rwkw @11psi ,I did ask him if
He had boosted the turbo higher an he said not without getting it retuned.
I'm going to ask about the ECU today , but I'm guessing it has.
Lucky bugger know the only dynotuner in town an to prove power output or just give it a run on the Dyno for numbers cost him nothing
To get it tuned 600$, I. Can't get near a Dyno for under 1200$ here in canberra.
The car is a 98 model btw , an I've got nothing to do next weekend so might, take the ute for a run an take a look.
Who have you been talking to? Every tuner i have been to doesn't even nearly charge that.....
Currently 3 tuners with running Dynos (that are worthy): ESP, Autotech and ultimate tunes. They won't charge you nearly that much.
Edited by Anfanee
Any of those 3 that i mentioned ^^
I think it's around $180 ish to get your car dynod just to have a look at it from those places. Give those shops i mentioned a call and just compare the prices.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
