Can't remember where I seen it but I know I didn't dream it, Xforce I think make an electronically adjustable exhaust or muffler , anyway you can tone it down or open it up, just trying to track it down now see what there worth.
VAREX make adjustable sound exhaust, however it's illegal. I believe the HSV's came with this feature, the loudest was 90dB and low was X. However, you can set loud to be 108dB and low to be 80dB. Cops don't like you being able to adjust the tone when their not around etc. My cousin had it and it was pretty awesome. They're about $2k to fit and install last time I checked.
Edited by RosieR34
Rego muffler may fit r33, fits r32.
Im sure someone here has one for r33
Yep, I have a pissy tiny Diff Back Muffler sitting in the Garage. Bolts up to a 3" pipe.
Been offered a lot of help an advice from everyone, you know who you are, if there's anything I can do to return the favour, need an engine lift, ute for the day, how ever I can help,
I've watch the increasing loss of community spirit since the late 80,s it's great to see people with a common interest coming together an helping one another.
Thankyou
Daryl
  • Like 1
Afternoon all
Anyone ever seen this type ecu setup
It's on the high side for a nissTune
http://bit.ly/18swIej
That's the ebay link
But at start bid 550$ I can get a platinum pro or such for 450 more an have all the extras I might need later . Always good to have options.
Just haven't seen this type of setup
Cheers
Link didn't work on my iPhone , try this
Z32 Ecu with brand new Nistune board modified to suit R33 GTST RB25DET
End time: 3 Nov 2013 8:31:29 pm AEDT
View item:
I got a Z32 ecu modified correctly with a brand new Nistune board installed to run in a Series 1 R33 GTST, have tested it in my own car and everything is all good.
I have modded this ECU myself, so you can be sure it is working correctly with no issues. Can do the series 2 modifications for no extra charge after payment has been made before sending the ecu.
Pix won't copy.
Cheers
Ever wondered what it's like to get grabbed at 730am on a sat morning at knife point , cause an ice psycho your junky brother owes money to can't collect.
Well now I've got more time to work on the skyline.
Well I figured about half way to cooma , I wasn't going to be making the return trip , so I lined up the passenger side with a tree an went for it.post-120922-13838104783034_thumb.jpg
Least my aims still good .
Nice to be able to feel the left 2 fingers on my right hand
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
