So recently my R32 skyline has developed a horrible creaking noise that I thought was originating from the dash, today myself and a friend removed the entire dash only to find the noise still there, after driving around at 10kph with my mates head burried in the dash he determined it was the windshield creaking in several locations, other than calling up a windscreen repair shop to remove and refit the same windscreen is there anything else I can try?
https://www.sau.com.au/forums/topic/432870-creaking-windscreen/
We even tried fitting a mates strut top brace but that didn't help, it seems even rolling the car at 1kph an hour over gravel makes it creak, imo I think it is more that it is loose or something however pressing on it doesn't help at all.
Really odd, hopefully removing it and refitting will fix the issue.
It's probably not the actual windscreen creaking, but either the pillar or firewall or front quarter panel creaking. It would be from flex in the body.
Agreed^^
Body flex around the A pillar
Take the windscreen out and move the car around
If it still does it then some spot welds should tighten things up
A strut brace is too far forward to make a difference
It is creaking along the seal at the bottom of the windscreen, sounds like polystyrene rubbing now that they have changed the seal, I think the A-pillar is flexing causing the seal to scrub making the creak noise.
Where should I add spot welds in the A-pillar?
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
