just curious to see if anyone know if the M35 series 2 headlights will fit in the series 1?
has anyone tried this?
im thinking of getting a set from the later m35 and mod the internals such as put different projector, halos and demon eyes in (and maybe audi style LEDS) and installing them into my 02 model.
Thanks for your input.
Justin
https://www.sau.com.au/forums/topic/432882-m35-headlights-interchangable/
Alex putting series two on a series one wont fit. Putting series one on a series two will fit with a gap like you said.
The series two are slightly bigger so you will need to change bonnet, bumper and grill.
Anyone here know the easiest way about the headlight conversion to right-hand traffic on a M35?
There really is no easy way as such. I opened the original headlight, cut a bigger hole to reflector and installed Hella Bi-Halogen projector to the remains of reflector and painted it black. There is enough space in back of original headlight unit that height level adjustment (which is mandatory here in Finland) still works with no issues. I'm quite happy with the result!
  • Like 1
Ooo nice work :) Do you wanna make 2 other?? :)
You might want to eat them words Mark. It has been done on a Pascal Metallic gay blue one in Victoria....that car is dead now.
Parts needed: Front Guards, Front Bar, Front Bonnet, Front Grill and of coarse the headlights.
Front guards were not changed
Nokonzok.... Very nice conversion. Just one question, can you see the original globe holes in the reflector after the projector is fitted?
I'm thinking of doing something similar as it would cost too much to change to series2 hlights especially with all the extra panels required.
Thanks
Justin.
i mean craig that the series two light wouldnt work on the stock series one bumper. Naturally bonnet, bumper and grill would have to be changed. So i was right.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
