Am bringing about 6-7 S15's down... Its the annual MelbS15 DECA invasion for us :)
Boo!! I was shattered last time when I rocked up to see only one (Gold 33 GTS-T) Skyline participating! I think there were a couple of others that were running around in the morning but had finished by the time I got there.
Wish mine had an engine.... All this action on my door step but nothing to play with. Should pull out the Datto ute... Lacks horses though...
hi guys, want to join as my first track day and have a few questions:
is a cams l2s fine or has to be aasa license?
Is this a track day competition or skid pan?
How does it go with roll cage? any is fine? can i have a passenger without a roll cage?
Do they have tire fitting facilities if i bring my own tyres? also do they sell new tires there too?
Hi Andrew,
Cams L2S is fine, you'll also need to show your current Affiliated Car Club membership card (like SAU VIC for example), AASA is the other option...
It's skid pan with some Timed Back Track work, it's definately not a track day. Youtube for DECA Long Wang for examples of the Back Tracks...
Yes, Yes Yes... Do not have to have a cage to race, do not have to have a cage for passengers, it is not a high speed event... chances are the fastest you'll go on the day is about 130kmh on one part of the Long Wang...
No tyre fitting facilities, the skid pan generally does not chew through tyres too much, unless you're deliberately trying to destroy tyres, you won't need fitting facilities... I'd recommend bringing a spare pair of wheels for the rears if you're planning on driving back to Melbourne and think you'll be finishing a set off.
Thanks for the reply Simon, when you say i have to be a club member, is that a payed sau member or unpayed counts too?
Also do you know much on driving an unreg vehicle with a permit to deca?
Paid & entered :)
perzn_34 - you need to be a paid member of SAU-VIC to have access to obtaining a CAMS license.
& in regards to unreg vehicle permit - when I had my silvia on permit after I'd just imported it, it only allowed me to drive the car to & from workshops & vicroads for the purposed of repairs to gain a roadworthy certificate.
Basically if you get pulled up you have to be able to prove you a driving the car to either a workshop for roadworthy purposes or to vicroads for registration purposes - I don't like your chances of driving to DECA on a permit if you get pulled up.
Paid & entered :)
Tell them you're taking it to Ken Muston Automotive (where I work here in Shepp) and you'll be right! "I promise officer, they're really good there!"
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
