Good work Ryan and co. Maps look killer! Gunna slide the Sil so much!
Here is the event schedule:
Event Schedule
Got approval for the skidpan runs in the morning - check them out!
3 spots left - get on it!
OK since everyone is excited about the new maps good time to bring this up:
NOTICE TO ALL COMPETITORS REGARDING FIRE EXTINGUISHERS
Please make sure your extinguisher is held in by a metal bracket. Make sure this metal bracket is bolted down to a metal part of the car with bolts NOT self tapping screws and NOT to plastic panels.
Also make sure you have a bracket that holds the extinguisher with a metal band.
NO GOOD:
GOOD:
If you dont have these things you wont be able to compete until you do. Cheers.
  • Like 1
Yep, gotta be a fully metal bracket, with a metal strap around it, as the moulded plastic brackets like to snap... and if its not high tensile bolted to a metal part of the car (Between the bolts that hold the passenger seat in is a great place) then it can break free as well.
There's no way the bracket in the top picture would be able to hold a 1kg fire extinguisher if you hit something (20g+)
as what manny said, my bracket (which has been ok in the past for track days and the 6-7 DECAs ive done in the past...though it was awhile ago...) is a combination of the top picture - metal bracing but also has a metal band..
if something has changed recently with that and I need to update something, better let me know..
http://www.melbs15.com/extras/stuff/fe-mount-3.jpg
NO GOOD:
GOOD:
What is a fire extinguisher?
Which way do you go around the skid pan?
I have a hand held camera, is that ok to use while I drive?
:banana:
  • Like 1
:banana:
I have driven past the chequered flag and water barriers do I keep racing?
How fast is 80% and how can you judge/ prove the percentage in which I am driving?
Speakers held in by gravity ok?
Do I have to have all wheel bolts fitted?
If it passed at winton you have to pass me!!!!
If we getting on this topic.
if you have an amp and/or sub box in the car, it must be bolted down to metal as well. self tapping into the back of your fold down seat in a 180/300 is not going to cut it.
if you take your amp out, don't let the positive cable sit there with no fuse against the metal work, (and I cannot believe I have to tell some-one that)
yes your battery is not in the cabin with you, it still needs to be bolted down.
to save us the hassle, take the damn macca's/bottles of water out of the back seat b4 you get your car checked.
when you get you car checked, your attire is as well, have your long sleeve top and pants on, and have your helmet.
don;t turn up in your shorts and thongs saying your getting changed later.
take spare Tyre out, no-one wants it and no-one will steal it.
have all your wheel nuts on and tight...really why do I have to say that??
oh and have fun.
and don't laugh at my car..
  • Like 1
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
