This car has been my pride and joy the past 2 years. I have looked after this car, oil changed every 5000km. Previous owner did ground up build, respray and inspected all parts before reassembling. This car is in great condition.
Has had a full respray in Mazda colour silver, and some seam welding has been done on the underside before being sprayed.
Suspension:
Most of this stuff was done when it was resprayed.
D2 Coilovers
Adjustable Camber Arms Front and Rear
New wheel bearings
All new Urethane Bushes replaced throughout
New Ball Joints
Rebuilt CVs
Supension Arms removed and Powder coated
Varostoen 19in Wheels in Matte Black (TE37 Lookalike)
Kumho KU19's all round
Brakes:
DBA 2500 Rotors on front
Stainless Steel Braided Brake lines
QFM A1RM Pads Front and Rear - These are quite noisy, my next pair would be a little more street orientated. They have great bite but can be quite noisy when used lightly.
Motul RBF 600 Brake Fluid
Diff was fitted with Nismo clutch packs and re-shimmed at Award Diff/Gearbox with recipts. R32 GTR Diff's are 1.5 way LSDs.
The front diff had an oil change when doing the CV joints.
Engine:
New Front Main Seal
New Gates Racing Timing Belt
New Clutch Fan
New engine bay seal
New headlight protector seal
New HKS Metal inlet gaskets
New heater hoses under inlet manifold
Splitfire Coilpacks
Nismo Twin Plate clutch
New Coil Pack loom
Relocated oil filter, with oil Cooler
Moroso 3quart Accusump mounted in boot
Earls Stainless Braided -10 lines on Oil Cooler and Accusump
Penrite HPR 5w-40 Synthetic
Oil systems takes roughly 7L
Interior:
GTR Seatcovers
Sony AUX Headunit
Momo Steering wheel
Jaycar 5" speakers in the rear
Mongoose Alarm fitted at Carbon Car Systems
I have a large folder full of recipts for money I and the previous owner have poured into this car over the years. The Air Conditioning has been a project on this car, It works but the gas leaked out. I found a large leak out the back of the compressor, so a 2nd hand one has been fitted, and the system is filled with nitrogen ready to be re-gassed. Depending on how quick it sells will depend on weather i get this fixed first or not.
It will be sad to see it go, but i don't see the point when i don't use it enough. Am happy to answer any questions about the car.
I also have an RTA History check that i paid for when buying the car.
This car is mildly stock, as i never could commit the funds to going all out on an engine build/turbos etc. It has a few things i've probably missed but come and inspect for yourself. Have tried to upload as many photos as possible so you can get the best idea about how it is. As you may be able to tell i'm no photographer! Couple in different lighting, all were taken the same day.
Inspections welcome.
Call Aaron on 0412 508 903. Located in Dundas Valley.
Cant seem to upload pics - Pic on Carsales advert http://www.carsales.com.au/private/details/Nissan-Skyline-1992/SSE-AD-2383575/?Cr=2&sdmvc=1
https://www.sau.com.au/forums/topic/432924-syd-1992-r32-gtr-21000/
  • 4 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
