So I've done some more researching lol. It appears I need a bigger pump and not bosh cos they only have 500hr life on e85 and somewhere between 1000 and 2000cc injectors and then a tank of nectar. I guess the hunt for parts begins
I've read everything and hence my surprise at some of the recommendations. Should have been clearer that I was whinging rather than asking. Seen enough threads to know what miserly GTR owners have shown works.
I was expecting to install the turbos and run stock piping and intercooler. But hard to TELL the mechanic what is best when he considers it his job to know. So new mechanic may be the way to go.
So thanks everyone for the usual "assistance".
does the fuel rail need to be replaced? I read on one thread it does then in another it doesn't. I wouldn't think you would have to. And what do u guys recommend minimum cc injectors. There are some 800cc for sale that say e85 compatible.
Stock fuel rail is fine.
Injector sizing is dependent on what you want from the car power wise. Usually 1000cc Xspurts are what I recommend, unless you want more than 400kw in the future on e85.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
