Hey guys,
did a track day a month ago and in the last few laps i missed the gate for third and when i pulled into the pits i noticed the shifter was sitting/tilted off to the left.
From a birds eye view it sits about halfway between 1st and 3rd. The gaps between 1st 3rd and 5th feel the same . Since i have replaced gear and engine mount with no success.
I now think its either a crossmember or chassis. It was a grip day and my car was running shitty street tyres and about 200rwkw with spring rates 6kg front 4kg rear and strut braces all round.
Cheers
Patrick
There is a detent and spring on each side of the shifter which centralises the shifter - perhaps one of the springs has bent or jammed, or you've sheared off the detent pin? They're behind a large 27mm (from memory) headed bolt either side of the extension housing close to the shifter mount plate.
Yeah i was thinking that but thought it would do dog leg into gear which it doesnt bit also movement distance side to side from shifter current position is even. Ill have a look thoigh. Cheers
  • 3 weeks later...
