First checkout the link below for proof I can be trusted to post as I'm an ebay POWER SELLER:
http://feedback.ebay.com.au/ws/eBayISAPI.dll?ViewFeedback2&userid=iphone.addiction&ftab=FeedbackAsSeller
I'm willing to negotiate if your taking multiple items:
Apexi PFC + Manual (for R32 & R33 GTR) $700
Blitz i-Color SBC Dual Solenoid $600 (Only USED for a couple of months, before uninstalling for storage almost 3 years ago)
AEM 8 Channel CDI Module $400
1996 R33 GTR Turbos done less than 100,000kms $400
JVC stereo RRP was $2700+ $350
Datalogit USED less than 10 times $320
pexi RSM Limited Edition + G-Sensor $250
TR 485cc Injectors x 6 $250
pexi FC Commander FCC3 new Style Multi-version 415-X001 $240
Innovate XD-16 (Gauge Kit) USED less than 10 times RRP$265+ (or take it with the LC-1 for $300 RRP$360+) $185
GTR ECU $180
Apexi 3 Bar Pressure Sensor 499-X001 NEW $160
Apexi 3 Bar Pressure Sensor 499-X001 USED less than 10 times $130
R32 GTR Main Gauge Set $150
Innovate LC1 (Wideband Kit) USED less than 10 times RRP$200+ (or take it with the XD-16 for $300 RRP$360+) $140
AEM PLX EGT (Exhuast Gas Temp Sensor Kit + Adapter for O2 bung) USED less than 10 times RRP$155+ $115
Nismo Front Strut Brace $120
R32 GTR Rear Spoiler $120
R32 GTR 3 Gauge set $120
Apexi Boost Solenoid 499-X003 for AVC-R or PFC $100
GTR AFM done less than 100,000kms $110 (*EACH)
R32 N1 Bonnet Lip (Preped & Ready for Paint) $100
GTR Coil Packs x 6 done less than 100,000kms $100
R32 GTR Climate Control $90
Sard Fuel Pressure Reg $90
Apexi Power Intake Dual Funnel Universal 75mm Air Cleaner NEW $80 (Each)
Stainless Steel Decat pipe 3" (with O2 bung & plug) + 2 NEW Gaskets $80
Hicas Lock Bar NEW $80
Alternator $80
Blitz DTT Turbo Timer (displays boost can be set on Auto using boost/vac or time) $55
Blitz FATT Turbo Timer $45
22x Narrow / Light-Weight Wheel Nuts + Tool for Thread 1.25 x 12 $55
Apexi Boost Pressure Sensor 499-X002 for AVC-R $50
HKS Turbo Timer with NT-1 Harness (vehicles suited are listed after the harnesses below $50
R32 GTR Ash Tray $50
R32 GTR N1 bonnet lip Needs Attention $40
R32 GTR Fuel Rail painted RED $40
R32 GTR Full Set of Blue LED's for Gauges $30
Fuel Pressure Gauge $25
Apexi Boost Pressure Sensor Harness NEW or USED $15
Turbo Timer Harness NT-1 for BNR/HCR/HNR32 S/PS/RS/RPS13, A31, RNN14, VNW30(95/8-On), C23(95/8-On) $20
Jack NEW $20
Rim Spacers 5mm $20
Cheap & Nasty Boost Gauge NEW $15
R32 GTR Headlight Relay $10
YOU MUST CONTACT ME BY PM OR EMAIL
Pick up from Wyndham Vale VIC (sometimes Dover Heights NSW)
Or
Postage with Tracking $20 or with Signature $23
Contact Brett at [email protected]
KD-AV7008 wiring diagram.pdf
Edited by Sydneyactionman
  • Like 2
pic/model of jvc stereo?
I had already attached a PDF that gives details of the model! Here are some photos!
As per the photo the original price from JB hifi was $2599 but it sold for up to $3K in other places!
NEW PRICES & WHATS LEFT:
Apexi PFC (for R32 & R33 GTR) $700
Blitz i-Color SBC Dual Solenoid $580 (Only USED for a couple of months, before uninstalling.)
1996 R33 GTR Turbos done less than 100,000kms $330.
JVC stereo $350 (RRP was $2700+)
Datalogit USED less than 10 times $300
Apexi RSM Limited Edition + G-Sensor $250
GTR 485cc Injectors x 6 $210
Apexi FC Commander FCC3 new Style Multi-version 415-X001 $230
Innovate XD-16 (Gauge Kit) USED less than 10 times RRP$265+ (or take it with the LC-1 for $300 RRP$360+) $180
GTR ECU $160
Apexi 3 Bar Pressure Sensor 499-X001 NEW $150
Innovate LC1 (Wide-band Kit) USED less than 10 times RRP$200+ (or take it with the XD-16 for $300 RRP$360+) $130
AEM PLX EGT (Exhaust Gas Temp Sensor Kit + Adapter for O2 bung) USED less than 10 times RRP$155+ $110
R32 Nismo Front Strut Brace $120
R32 GTR Rear Spoiler $110
R32 GTR 3 Gauge set $100
GTR AFM done less than 100,000kms $100 (EACH)
R32 N1 Bonnet Lip (Prepped & Ready for Paint) $90
GTR Coil Packs x 6 done less than 100,000kms $90
Sard Fuel Pressure Reg (Cost me $200, it's NOT a $50 knock off) $80
Apexi Power Intake Dual Funnel Universal 75mm Air Cleaner NEW $70 (Each)
Alternator $80
22x Narrow / Light-Weight Wheel Nuts + Tool for Thread 1.25 x 12 $50
Jack NEW $20
Rim Spacers 5mm $20
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
