Hey everyone
Have the following for sale:
- R32 GT-R HKS Damper Coilovers. - $600
Adjustable for height with helper spring on the rear and adjustable dampening. Not sure of spring rate but was fairly good for the street ( better than Taiwachinese stuff ). Didn't have any knocks in my cars. Has the usual dirt and grime from being in a street car. No knocks or leaks.
I have changed coilovers for no other reason, than I can, thanks to my relationship with Fulcrum/Tein. They weren't removed due to anything wrong with them. Just want quick sale.
- R32/33 GT-R APEXi Power FC with Hand Controller - $700
In the car now and works fine. Cant comment on condition etc other than that. Currently tuned to work on 800cc Sard injectors ( also selling, see below ) with standard airflow meters and Tomei Poncams. Makes 330-340kW@wheels.
- Sard RB26 Injectors. - $500
These were in the car when I bought it. I havnt had them out to check serial numbers, but based on the numbers in the computer, and the purple collars ( which is dirty and faded ). They appear to be 800cc. Car is making 330-340kW@wheels with them in stock rail with stock reg, so the numbers add up. NO issues, idles fine etc Has NOT, i repeat, NOT been used with E85. Only BP98.
Why am I selling them? I'm installing Haltech Platinum Pro with flex fuel sensor and bigger injectors and surge tank etc so can runE70-E85. Selling is to fund this as they wont magically fall in my lap for free.
Everything priced for quick sale.
Would prefer pick up.
Email [email protected]
post-60913-0-77722100-1381223833_thumb.jpgpost-60913-0-50828000-1381223838_thumb.jpgpost-60913-0-21335900-1381223842_thumb.jpgpost-60913-0-43466300-1381223845_thumb.jpgpost-60913-0-45403200-1381223849_thumb.jpgpost-60913-0-39580900-1381223857_thumb.jpgpost-60913-0-63411600-1381223862_thumb.jpg
Coilovers are now sold
Power FC w/ hand controller and injectors still available. Are running on car right now so can see they work
    • Correct, I didn't put GT-R in the same category in this thread, incase I offend anyone. But @GTSBoy  knows my true thoughts on all Nissans.
    • Get more oil pressure sensors. I have 3 purely because trust no-one. It would be worth checking (if not already) if it happens on every shift. Like boring, 2-3 shifts at 60kph making 10kw with no obvious G-force on a shift with mega power. Does it still drop? Does it drop less? What if you shift at 5000rpm or what have you with no load?
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
