Hey everyone. The latest issue of Motive DVD is currently available for discounted pre-order until midnight Tuesday 15th when deliveries start.
This means it is $10 instead of $15 and you get it first. It will then go on sale at WTAC and at newsagents first week of November.
The DVD has the following features:
- 2013 Castrol Edge Drag Battle
- 2013 Castrol Edge GT-R Challenge
- Nitto R34 GT-R
- FT86 Review
- Motive Garage Pulsar Turbo
- Motive Garage R32 GT-R
- 2013 Hi-Tec Oils Figure 8 Drift Series Rd1&2
You can order it here: http://www.motive.bi...t/motive-dvd-19
We are also holding a CInema Premiere for it in Sydney on the 10th and in Brisbane on the 14th. More info here:
Sydney: http://www.motive.bi...-gt-r-challenge
Brisbane: http://www.motive.bi...-gt-r-challenge
https://www.sau.com.au/forums/topic/433037-motive-dvd-19-out-now/
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
